Sounds a bit dodgy to me.....cant the pipe go up in a cupboard or some other more sensible route?
Bit hard to explain but basically no. Well I could run it visibly up the wall or box it in but that would look naff.
I had some buried hot pipes in a house I had years ago, the wall would always crack, not sure if thats normal or not....Bit hard to explain but basically no. Well I could run it visibly up the wall or box it in but that would look naff.
ProbablyThey were probably not insulated and wrapped as they ought to be.
I think that essentially now the norm, and probably has been for quite a long time. However, if one goes back a few decades, then pipes buried in walls (solid or 'hollow') were seemingly more common - and it's one of those which I once hit with a drillAll of my pipes are either surface, and visible, or hidden by cupboards, boxed in. In the kitchen,
I may, of course, be wrong but, as I've said, I don't think there are any such zones for pipes and, as we've both said, it would be difficult (often probably essentially impossible!) to define them in a way analogous to what we have with cables (since there is usually little nothing analogous to an 'electrical accessory' along the length of a pipe run).Might be an idea to ask on the plumbing/heating forum if any of the qualified lads know how or how not any permitted zones for various pipes/tube play out.
... But with pipework I imagine it is much more difficult to define.
Fair enough, but in that case the cable (whether in conduit or not) was clearly not in a 'permitted zone'.In the past, I have managed to angle grind/drill through the thin conduit around cables that had nothing to indicate that they are there. One time was my own home. It was a lighting cable. It ran down the middle of a wall. There was nothing on either floor to make it obvious.
