3 zone smart thermostat
3 Aug 2009
Somerset
Hello
I’ve used the tado previously and it works great. Problem is that it’s only 2 zone, I need 3. 2 heating and one water.
Is there anything out there that can do this?
Not interested in radiator thermostats.
Cheers
Do they assist with install like tado did/do or are these plumber spec to install?
Looks like it, yes, if you want the zones controlled separately.
So if have to use the other thermostat and get power to it?
You can use one thermostat but that effectively means the two zones will become one. And if you do that you can use any smart thermostat like Hive etc.
Okay so a zone implies separate thermostat and controls? In my case I’ve one zone with two programmers then?
You seem to have two zones with one thermostat. Can you switch them on independently? Do they heat different floors/parts of the house?
