Garage Door vs Brick Sizes?
14 Sep 2005
Englandshire
I'm designing a new garage. Hopefully a simple question...
How are garage doors normally specified? They're normally still sold in increments of feet and inches, then you add a 75mm frame and end up with some awful random measurement, which is often miles away from standard brick lengths.
E.g. a 8'0" x 7' door is 2578w x 2191h including the frame.
The next biggest brick opening would be 2710mm, leaving a 66mm gap either side of the frame.
The next biggest opening height would be 2250mm, leaving a 59mm gap at the top.
How are newbuild garages normally designed? Do housebuilders fit imperial, metric or brick-sized doors? If so I need to find some.
Thanks!
You can get garage doors in both standard off the shelf sizes and made to measure the opening. Size of opening depends on which type of door you want.
Thanks!
7' x 7' plus goal posts i.e. 6" for the sides 3" for the top.
The metal framed garage door we had fitted had a lot more adjustment than the wooden posted one we had previously. Trims can be added to the sides and top.
Designikng to standard brick format is all well and good, but half decent brickies will get the dims you want.
