Hi all.
I have a recent renovation install of an ufh systems in my downstairs, with rads & towel rails upstairs.
My boiler is a Worcester Bosch Greenstar 30kw system boiler connected also to a hot water tank. The boiler has a self regulating valve to reduce the heat flow temp when required.
I have had issues with my UFH from the very start with regard to floor temp.
My system was designed by Wunda, supplied as the full kit and fitted by a plumber who installs a Wunda system on the trade side at least once per month.
My issue has reached a point where Wunda are saying it’s a hot water flow volume problem that is overpowering the blending valve which cannot blend the heat down.
I have 5 loops. 3 in a large kitchen diner, circa 118m linear each. A hallway which is linear 55m, and a sitting room of 90m.
There was some question marks over the 100+m loops but Wunda are happy that is fine, even though the flow rates do not meet their guide of 3.0.
My main problem has been when the wider system closes off and leaves just the hallway running. The temp on the flow rises to 55/60deg with the blending valve set to minimum. As a result, the floor is reaching 30+ degrees quickly and shutting off.
I have LVT so it’s been freaking me out with these crazy spikes.
Wunda sent me a new blending valve which made no difference. We also checked the return to make sure there was no kinks in the plastic section of pipe, by running a new pipe free flow up the stairs and connected, behaviour was the same.
I have a bypass in the loft which is doing its job when needed.
The bar pressure at the manifold is 1.8bar so all good. I have also added a second bypass at the manifold.
No air, that’s been checked and run through well, system is very quiet.
The only way I can get the system to behave well is by bringing all 5 loops together on the controller so the volume can spread better, however I’ve lost room control and control of the floor probes in two areas.
Wunda are saying it’s because my boiler is pushing to much water and the blending valve/manifold cannot deal with it.
Their recommendation at the moment is to add further restriction before the ufh to help. However there is concern on that where the long loops may then get even less flow leaving the far ends colder than they should be.
They did say to reduce the boiler flow but I can only go down to just north of 60deg where it’s feeding the hot water tank.
It’s all in 22mm pipe. Pump is a Will Para which I have tried on variable and constant. Power 2 & 3z
I think I have covered most of the setup to help paint the picture.
So my question is; does this sound like what they say? The boiler is too powerful when just serving the Ufh if runs are short and not enough cold is returning to cool the flow temp?
If the hot water was being circulated, and or the upstairs heating was on, they say it would be fine. Could it be a blending valve not up the the task?
It appears right now that if they are correct, I need to either restrict the flow somehow whilst not effecting upstairs heating and hot water. or maybe there is a blending valve that can handle the volume with a lower mixing temp? My valve I think runs at 30deg on minimum (when not being over powered), would a valve that can go down to 20 or 25deg help?
Thanks in advance for any advice or comments.
