- Joined
- 22 Aug 2024
- Messages
- 105
- Reaction score
- 3
- Country
(Kind of a follow up post to my previous post here but you don't have to read it as this is pretty much a standalone question)
We Moved in not so long ago and sadly bad luck bit us in the arse hard. My wife became ill and had to give up work and it'll be that way for around 2-3 more years. Ive had to cut my hours down to a minimum. So, we have zero savings. So, once again WE HAVE NO SAVINGS lol (just adding that as sometimes the replies are "Just pay somebody to lay a new one etc" <3
Due to my wife being ill I wanted to make the outside look nice and for it to be somewhere nice to sit.
Outside of the backdoor is a small patio area but the slabs are broken or raised etc. So, I started looking into what I could do to make it look a bit more peaceful out there.
At first i thought about a decking kit (Cheap and cheerful) but I decided to go out and JUST check they'd been laid correctly. As in if it had MOT under it etc. We were told when we moved in it had been laid professionally 12-15 years back..
So, yesterday I decided to lift one up and take a look.. I did so and found this (see photo). Does this mean there is no mortar and no MOT? It looks like there's a trace of sand but that's it. Am i correct in thinking it's just been laid on mud with a BIT of sand? It would Explain why the slabs are broken/raised in some areas. Thank you.
EDIT: Added extra pictures once i got home from work.
AS said below i've stuck a pole in and it's easily pushed in a good 1-2Ft without any resistance.
