- Joined
- 27 Jan 2008
- Messages
- 29,248
- Reaction score
- 3,588
- Location
- Country
As has been says, if the product does not claim to be "bidirectional", it almost certainly isn't intended to be.
Who knows?!Could it be something to do with how the electronics are powered?
Are you talking about a 'something' within the device (i.e. it's electronics)? If so, then see what I've just written to davelx.I think it is where something is powered from the devices output so once it trips the supply is auto broken, so when used the other way around it remains powered up even after it has tripped.
All true, but not really relevant to this discussion.The original RCDs were pure mechanical, no electronics were used, but early RCDs had problems. Any slight distortion when torquing up the terminals could cause them to fail. The use of electronics has resulted in improvements, the early RCDs did include type S, but types AC, A, F, and B were unknown.
Perhaps, but I'm not convinced. If, at a certain point in time, one possible feature of a type of product is pretty rare, would you really expect the data sheets of all the others to indicate that they didn't have that particular (rare) feature?If I had found a data sheet dated 2010 I could expect there be reference to mono or bidirectional, but the data sheet was dated 11-12-2025 by which time there should have been a reference to if bidirectional or not.
Exactly.Most of the data sheets I read are for electronic components rather than circuit production equipment, but my experiance is that data sheets almost never talk about features that a product *doesn't* have.
Thanks - that all sounds pretty credible.This whole 'bidirectional' effort is meaningless for the vast majority of circuits.
It's mostly hype shovelled up by the issue of Amd3 to BS7671:2018, which was touted as an 'emergency' amendment to add such things.
The main driver was the usual bandwagon companies slinging in PV and battery systems onto older installations with consumer units that were never designed for them, with such items being stuffed onto circuits with shared RCDs or poking RCBOs in there because the uneducated installation slingers were told that RCDs must be used for everything as they make everything safe and proper.
Unidirectional breaks the line pole supply side only.Thanks - that all sounds pretty credible.
So what, if anything, is the difference between a 'unidirectional' device and a 'bidirectional' one? ... and what, if any, problems are there in using a 'traditional' device with supply and load connections reversed (other than the small potential issue {which has always existed, since long before anyone had heard of PV} if the test button is 'held down' for appreciable periods)?
