Is it acceptable to connect a radial to a spur via a 13A plug?
True, but that's equally true whether the other end of the cable is connected to an FCU or a plug.
A FCU can't be unplugged and yanked on, a plug can.
Also flex is less good about "staying where you put it" than T&E is, and this is exacerbated by the fact that clips may be a loose fit.
However, it's not necessarily totally easy to get T+E into a BS1363 plug.
It does require some technique, at the scales of a 13A plug, a 2.5mm² solid conductor is more like a rod than a wire. My usual technique is to remove the terminals from the plug, form and terminate the conductors outside the plug, and then drop them back in.
Cheap plugs are actually easier because the pins/terminals usually just slide/fall out, while fancier plugs often have them restrained in the plug base.
Is that really true? Is there not, in fact, an argument that stranded conductors are preferable to solid ones in screwed terminals?
There is a big difference between "stranded" conductors and "fine stranded" conductors. The former are fine, the latter can be a bit unruly, finding their way up the sides of screws, or worse finding their way out of the terminal completely.
BS7671 is rather vague on this, merely talking about "suitable terminals" and "suitable preparation" but not rigidly defining what either of those things are.
I think we're probably quibbling about minor issues which we have agreed "are not show stoppers".
If the cable is clipped to the surface of a wall/whatever, I don't think that's much more true of a plug than of an FCU, is it?
Again, if the cable is clipped to the surface of a wall/whatever, I think that some barrels are being scraped here, aren't they? :-)
Same here, but it's certainly possible (with 2.5mm² or smaller T+E).
Agreed.
I don't disagree with that, but in what way are you suggesting/implying that the terminals of an FCU differ from those of a socket?
True, but probably 'understandable', given that a comprehensive definition of "suitable terminals" would probably be next-to-impossible. As you have observed, spring-loaded terminals might well be the ideal solution.
It's all very situationally dependent. I think it's easy to get into a situation with a short run of flex from a plug to a socket, where the clips hold the cable in place, but do not provide adequate resistance against the cable getting yanked.
Much less likely with a FCU, because you don't have the yank-prone loop of cable from the last clip to the plug.
I can't disagree, but I do think that barrels are being scraped - that 'yank risk' surely exists with almost anything plugged into a socket - and, in fact, probably a much lower risk when (very unusual for 'plugged in' things) most of the cable is clipped to a wall?
The same 'barrel' :-)
If the output from the FCU is a cable exiting through the faceplate and then clipped to a wall, there'll be at least a bit of a 'loop', allbeit pretty close to the wall.
that all begs the question
‘Tis a great shame (IMO) this interesting phrase is mutating into a paraphrase of “raises the question”..
I have had one fail with the individual socket fronts breaking free of the body. Granted I abused the thing
Hopefully you fed back to the manufacturer?! Sounds like something they should look to address with a product revision, as (if I understand your claim correctly) it’s conceivable a 3 pin plug could apply the same torque if pulled as a euro plug would, potentially causing the same fail?
I wasn’t particularly recommending that one, it was just the first reasonable brand from a reputable supplier that I found amid the wash of tosh from Amazon
Interesting comment. I would not have thought that there has been any 'mutation' in remotely recent times. My memory may be failing me (it often does these days!) but I have say that I would have thought that the phrase "begs the question" has been in widespread common usage throughout most, if not all, of the very many decades of my life to date.
As for your suggested alternative, in what sense do you think that a question can be "raised" - does one have to attach it to a hot air balloon, add some yeast or what ? ;)
The English language, particularly as it is 'commonly used', can be pretty intriguing. illogical, irrational and inconsistent, but maybe that's why many of us 'love' it so much? !
As we have seen, that's somewhat open to debate. If that were always true, it would presumably open up the possibility of all sorts of loopholes which people might try to exploit in order to evade the Wiring Regs :-)
In any event, I think the scope for 'debate' is probably considerably reduced by this explicit statement in Approved Document P, which presumably reflects the intent of the authors of BS7671 ...
So do all your extension leads comply with the regs?
An extension lead Is not part of the fixed wiring as it’s plugged in
Hah - an extension lead with a plugtop in connecting cables to a fixed lighting circuit (plastered into the wall) , is that lighting circuit fixed mains wiring and the fact it`s run from the extension lead then does this make it a part of the circuit that is not fixed mains wiring ???
It needs I & T right from the circuit origin at the consumer unit to the last lamp doesn`t it?
Plus "Click" Blue plugs and sockets thingys (other maes are available) are they not fixed mains wiring???
No, perhaps I should have, but as I said I abused the thing.
The problem with Europlugs in UK sockets (besides the lack of overcurrent protection, which is less of an issue in an extension lead) is they can get caught behind the socket face, exerting a significant force on it when pulled out.
