This in turn gives links to the BEAMA Technical Bulletins, and it does seem if nothing to say it is unidirectional with arrows, load, in, out etc. Then considered as being bidirectional.
It does say that - but, hardly ever (in the last ~40 years) having seen one with such markings, I'm coming to wonder whether (despite what I previously thought) significant numbers of 'unidirectional' ones actually exist, or have ever existed??
I've just looked at one of my 'spares' on my shelves. Since I don't recall ever having had to replace an RCD (MCCB) in any of my CUs, I suspect that it is probably well over 20 years old, and it is certainly typical in appearance to what I recall of virtually all those which I've seen. It bears absolutely none of the markings you mention. The nearest to a 'marking' of any terminal is (as you can see in photo) an "L" adjacent to the top left terminal (close to the test button) - that presumably being the terminal into which the supply-side L would normally be connected...
The diagram on the side is interesting ...
... although none of the terminals on the device are actually numbered, the fact that they are referred to as 1/2 & 3/4 at one end of the device (top of diagram) and 2/1 & 4/3 at the other end (bottom) seems to suggest/imply that it is meant to be 'bidirectional'. More to the point, the third pair of contacts on the trip mechanism (for the 'test circuit') (one of the methods I've mentioned for addressing the 'test button issue') mean that (provided the device operates when the test button is pressed - see below) the potential 'test button issue' will not arise, in which case I presume it can be regarded as 'bidirectional'. The diagrams below show the current paths whilst the test button is pressed, both before and after the device trips (if it ever does!).
In creating those diagrams, I was reminded of the fact that almost all the methods of addressing the potential 'test button issue' (to make devices 'bidirectional') I have mentioned would probably 'fail' (in the event of prolonged depression of the test button) if (presumably due to 'being faulty') the device did
not trip when the button was pressed. In fact, the only approach I've mentioned that would still 'protect' in the absence of a trip would be some sort of direct (mechanical or electronic) restriction of the 'test current' to a very small duration. However, maybe those designing these 'bidirectional' devices felt that it didn't matter that they could 'become unsafe' if the device didn't trip when the test button was pressed - since in that situation one would hope (but could not be certain!) that the device would be replaced, anyway??
Whatever, if standard devices were essentially 'bidirectional' more than 20 years ago, it would seem unlikely that there would have subsequently been any (seemingly 'detrimental') changes to producing 'unidirectional' ones.
The only problem is one needs to remove CU cover to see those markings, so not really any good for plug and play.
Indeed so - which is why I'm not sure that any of these discussions or 'statements' about the characteristics/markings/whatever of RCDs are actually very relevant to the issue of 'plug-in solar inverters'.
If a EV socket can have a special V2G compatible, why not a BS 1363 socket having a S2G compatible. (solar to grid)
I suspect that there is no reason - but the whole idea of 'plug-in-solar' would presumably be that it could be plugged into any 'ordinary' BS1363 socket, isn't it?
