How do I go about this?
This was discussed at some length here Fridge motor ... Looking at it again, I'm not clear where 3-phase, or more, at the motor or supply, in ericmark's #22, comes into the discussion, but no doubt you will enlighten me!
It's a good example of the intriguing way in which discussions (not just here - virtually everywhere) can move from tangent to tangent, such that the 'origin' of the discussion quickly becomes 'an obscure matter of ancient history' - it really often can be just like "Chinese Whispers" :-)
• This thread started with the OP asking about how he could learn more about 'electrics', noting that he had problems with (and a dislike of) maths. Early on (#11) i suggested that the amount of maths needed in relation to domestic electrics was pretty trivial, and that far more important was a good understanding of basic electrical principles. In reinforcing that, I cited an anecdotal experience from decades ago when a so-called 'electrician' tried to tell me crazy things about the need for an additional RCD which illustrated that he didn't have the slightest clue about very basic electrical principles.​
• eric then jumped in and said that that 'electrician' may have had more of a point had we been talking about 'voltage-operated' earth leakage circuit breakers ((VOELCB, or ELCB-v), even though they were already seriously obsolete by the time of that anecdotal experience.​
• In #22, eric then broadened that issue (the fact that VOELCBs had given way to RCDs a very long time ago) by producing a list of things that had changed since he was first educated/taught about them. One of those observations was ".... go back 20 years, and with domestic we never saw a three phase motor, but today in my house I have at least 3, a fridge/freezer, a freezer, and a washing machine, possible the drier also has one?".​
• Quite a bit later (#50), after a lot of interesting, but irrelevant today, discussion about VOELCBs, you picked up on that statement from eric, expressing your surprise that he had talked about 3-phase domestic appliances.​
• I then explained what I thought he was getting at - not domestic appliances fed with a 3-phase supply but, rather appliances with a single phase supply that 'converted; that to provide a polyphase supply for the motor.​
• The subsequent exchanges between you and I are, as they say, then 'a matter of history' :-) .​
As I said at the start, I find these happenings pretty intriguing - but they do, at least for me, have the advantage that I learn about, and am able to discuss, a much wider range of things (maybe ones I'd never heard of, or thought about) than would be the case if discussions always remained 'on topic'.
The important thing, from the POV of OPs asking questions, is that those tangents do not start muddying the water until after the OP's questions(s) have been dealt with as best as they can be - which I would say is, more often than not, what usually happens.
Good summary
Does the introduction of 3 (or more) phase motors affect the operation of RCDs? That's what I was unclear about.
If numbers are imaginary, do they exist? ;)
I'd probably have to ask my 'littler' daughter that one, since she's the one with a degree in Philosophy :-)
Slightly more seriously, mathematicians and some engineers etc. would probably say that they 'exist', in the sense that they can deal with them in much the same way as 'real numbers' - but I'mnot so sure about the rest of the world's population!
Having said that, 'fictitious concepts' such as this can be very useful - as, for example, the concept of 'sucking' (as in 'vacuum' cleaners) or the concept of 'holes moving' in semiconductors :-)
Good summary ... Does the introduction of 3 (or more) phase motors affect the operation of RCDs? That's what I was unclear about.
Not at all. As I said,the discussion jumped dramatically, several times, and 3-phase motors (in domestic appliances) only got into it as part of eric's list of things which had 'changed' since his initial electrical education. Absolutely nothing to do with RCDs (or VOELCBs, let alone the OP's question!).
OK thanks
Definitely, I was of course joking. Complex number theory is a very interesting and useful branch of maths, with applications in several fields in science and engineering, AC theory for one.
Are you aware of Euler's formula, e^(i*x) = cos(x)+i*sin(x)? Three apparently separate areas of maths, exponentials, imaginary numbers and trig functions turn out to have this surprising connection.
Sure -and, in turn, I was essentially joking in my reply - particularly in relation to my 'philosopher' (actually now a barrister !) daughter. However, as we are agreed, imaginary numbers are not only of interest and value to mathematicians but also to those in other fields, of which electrical engineering is an important one.
I was aware of that formula, but have never had reason to use it - but, as you say, it represents an interesting coming together of a number of mathematical concepts (getting back to the OP, way beyond anything needed in relation to 'domestic electrics'!).
To the electrical engineer, or other people involved with 'wave mechanics' etc., I suppose that imaginary (particularly 'complex') numbers provide a useful way of dealing with 'vectors', in a manner which makes them more mathematically 'manipulable', the alternative probably being a lot of trigonometry!
