Where to put subfloor ventilation fans?
11 Mar 2011
London
I've got an old semi-detached house with a suspended timber floor across most of ground floor (area in green on drawing), mainly 4x2" timbers across a maze of sleeper walls with about 250-500mm underneath them. I have all the timber floor up so I can replace a few rotted timbers. I will also insulate between the 4x2" with 100mm Celotex, and foam and tape all the gaps to create an airtight seal.
An extension at back with concrete slab means no through ventilation front-back. The airflow into the side airbricks is small as it's down a very sheltered side passage, and our neighbour's subfloor is full of rubble. So probably very little side-side natural airflow too. I have already put a couple of extra air bricks in where I can, but the damp smell in the heart of the house is still strong.
I think subfloor fans are probably the answer. But where should they go? And which direction should they push the air? I have labelled pink 1, 2, 3 as possible places:
- Positions 1 or 3 would be replacing air brick with an externally accessible trickle fan like WMF Mori. Should they push air in or suck it out?
- Position 2 I could create a hatch in the cupboard floor for maintenance and use a traditional inline fan. From there guess you would want to push air back towards the air bricks?
- Other option would be to put an external fan in 1 but duct it through to the heart of the unventilated space. But should it suck or blow?
Or does anyone think I should do something else; my only other ideas are:
- Just rely on the insulation to stop warm damp air from house coming down into the void, and hope this stops rot (once sealed up will be hard to know)
- Treat the timbers with something to prevent dry rot?
- Fill the void in some way? I don't think it would be worth paying for a whole concrete subfloor. But are there any expanding foam treatments that could exclude air from the subfloor permanently?
Thanks - bit stuck with this one. But I know doing something now while I have the subfloor up will be a lot easier than replacing a rotted floor in 10yrs time!
Depending on the depth of the subfloor it may be a lot easier and much more effective to just remove the floor completely and fill the void with insulation and concrete.
We moved from a house with suspended floor to one with solid. It's vastly superior, with absolutely no worries about vents or rot.
I would put a fan in position 1 with a duct leading to the 'deadest' spot in the subfloor, which is probably nearest point 2. I would have the fan sucking air out of the subfloor, which would force air to be drawn in through all the openings and create some general air movement under the floor.
We insulated under the suspended floor of our lounge with 100mm of celotex when we replaced the floor due to a 100 year old mixture of wet rot and woodworm. I have been very disappointed with the results. The floor is no warmer underfoot now that it was before the insulation and the room doesn't feel any warmer either.
You don’t need sub floor fans .
It probably does if the original through-flow path has been blocked by the extension.
Are you sure there aren't any airbricks in the back of the extension? They're often ducted through the concrete in this sort of situation.
Otherwise, I'd definitely have the fan extracting, so that the air pressure down there is below that of the house. If you blow air into the subfloor then it will blow up into the house and stink worse than ever. You'll need to draught-proof the floor as well as possible, otherwise all the heat will constantly get sucked out of the house.
But concrete would be best, by far.
The solid floor should have ducting through it ? Are there external vents to extension? How could warm damp air defy gravity and pass through floor covering?
I think getting a full concrete slab poured would be too much hassle but I did wonder about foam.
Even if we leave the main void open, is it better to fill in tiny gaps like this between the external wall and the sleeper wall that the beams rest on? I could just use a can of foam for that, but it's not going to ventilate properly.
Yes thinking about it over the day I was thinking that would be the best way to mimic natural circulation of air through air bricks.
I am also thinking of sealing in the insulation with aluminium tape to try to stop any air movement between the subfloor and the house - for heat efficiency and containing smell. I think the air from outside is supposed to be drier than that in the house, although hard to imagine that from that dank side passage.
No ventilation out through the extension. Building Control did question it, but there were no air bricks in the old outrigger so no obligation to provide more insulation than was already there (probably why the dry rot was advanced even before the extension).
With all the floor up I should be able to seal it pretty well, celotex plus foam round edges, then aluminium tape.
I'll go for ducting from near 2 in the deadest part to the air brick at 1. I'll try for 110mm rigid circular but might have to go for the rectangular stuff if there's too many sleeper walls to get through. And direction pushing air from the dead area out of the air brick.
What about the fan? Should I go for:
- Replace airbrick 1 with a Mori fan to pull the air towards outside?
- Inline fan at 2, the other end of the ducting (accessible via a hatch in the cupboard floor) to push the air towards the outside?
I think you'd get more airflow pushing, and those fans are cheaper. But most people seem to recommend the air brick ones. Any ideas?
Sorry, but your comments in this thread demonstrate a poor understanding of how floor ventilation works. And you really need to be careful not to create the environment and the problems that you are trying to prevent, by applying the wrong way of thinking
It's not a case of insulating it, sealing gaps, stopping air movement between the habitable room and void and its definitely not the case of 'warm damp air from house coming down into the void' - heat rises! The void is not a room to be sealed. Do not seal the gap between the house walls and any sleeper wall or timber.
And you don't want to be pumping external air (whether by input or forced extract) into the void and in doing so create an artificial environment ripe for humidity and mould issues.
Floor void ventilation works by pressure differential and not by wind blowing through the void. This gentle movement of air prevents mould growth - even in high humidity air. That needs to be understood, before going down a route of elaborate schemes trying to stop something that might never happen in the first place. Secondly, it works by a state of near equilibrium, whereby the air in the void is slightly warmer than external air, and the surface materials slightly warmer too, so reducing the risk of air condensing. So that's why you don't want fast air changes and colder air being introduced by a fan.
Above all if there is no problem now, despite not being textbook correct, then what makes you think that there will be a problem in the future. Has the presence of the extension over several seasons caused an issue?
If you are dealing with a true ventilation issue, then you should get advice from someone experienced in that. That someone won't be the one that just quotes standard textbook stuff for non-textbook situations.
Just put some long ducts in. 110mm soil pipe is cheap and easy and you can core drill nice tidy holes to the outside. No need for fans, as said the air just "drifts" around.
If the subfloor stinks of rot then that's more likely a symptom of dodgy drains than ventilation.
I grappled for years with our last house, that stank too. Woodworm, dry rot, wet rot, the lot. I spent loads of time and money installing surface water drains etc outside. Then found out that the neighbour's downpipe was pouring directly into the soil and it was all coming our way due to the underground features.
Get an umbrella. The next time it rains heavily go for a walk and see what's actually happening. In your garden and next door too. You'll probably find overflowing gullies and gutters spewing water down the edges of the building.
