Screws pulling out on hinges
22 Nov 2018
Two of my internal doors the latch side rubbing so rather than planing that side it's better to tighten the hinge screws I believe but they're not biting hard into the lining. Take screws out and put in bits of wood and wood glue then screw back in straight away?
Miss job n knocks lol. He knew his stuff
Yes but wait until its dry, I use the round bamboo skewers, its like they are bade for the job, if the point end is really long then nip it a bit shorter with the wire cutters section on a pair of pliers and also cut it down to about 2 inches uou can then coat with glue and hammer it in as they are very strong that way, then just snap them off level when dry. Drill a pilot hole and use hinge tight screws.
I miss him as well.
I use matches with super glue to plug the hole.
Larger holes, perhaps wooden dowels with wood glue- longer wait drying time.
Out of interest, why are the hinges not rebated into the door edge?
I miss him as well.
Think I packed them out for some reason, must have been binding somewhere
