Abnormally high UK temperatures continue
Then why the smart arse comments about Uranus
Surely it's obvious, I'm taking the pi55 out of your comments. You don't seem to have a clue.
Milankovitch cycles, which are of the order of ten of thousand years, upwards, will have had almost zero effect in the period in which the planet has become radically warmer.
The effect, if you bothered to work it out if you could, is that they would have caused COOLING .
I find it hard to understand why someone would exhibit such ignorance of well understood things these days.
Unless of course it's all just to be a tiresome troll.
If you bothered to read what I said, it was blaim the planets ( milankovitch cycle ) on the world's climate , I didn't mention the temperature
You made a mistake there, you are supposed to say 70 years.
I picked the start of the Industrial Revolution.
A rapid rise or reduction is nothing new in earths history. GISP showed us that.
It showed nothing like the global average rise we've seen since human CO2 emissions started having an effect.
Stick to the Jew hating threads you are better at that than this climate malarkey.
Hard to stick to something I didn't do/haven't done/wasn't doing.
Feel free to prove that you haven't engaged in a disgusting lie by producing some Jew-hating posts of mine. Otherwise people might start to think that you're using that lie as a distraction.
You're still writing rubbish.
I repeat, those cycles have an insignificant effect in the last few hundred years. And it would be the opposite of what you imply.
Have you got it now?
Surely even you can't think global temperature and climate are not related.
No you are right, it actually showed bigger changes in decade's or less
Bit of a freudian slip there as I never said you have made any Jew hating posts.
No it didn't.
Stick to jew hating -- you are much better at that
you manage to join the dots perfectly well when participating in the Jew hating threads.
Nice attempt at derailing the thread onto your favourite subject. Do try to stick to the thread.
