Meter Reading Change for our Freehold
10 Oct 2014
Sussex
British Gas has called us and emailed us to request a change from the existing old electric meter for our communal hallway. (Landlord supply for a block of 4 flats)
The old one is still working. Our consumption is pretty low - 193.2 kWh for an annual cost of £239.94 (this is only for the communal hallway and outside light)
My take is not to change if it's not broken.
Any reason to change it?
The Electricity Act 1898 required that meters are certified for a finite lifetime and in domestic premises must be replaced when that time has expired. Induction meters like your are generally certified for 10 years, after which they must be replaced. It may appear to be working OK, but it's the accuracy that suffers as it ages so you can't tell just by looking at it. Yours look quite old.
https://www.gov.uk/guidance/electricity-meter-certification
Quite so.
It does. Does this perhaps relate to a 1992 calibration (or possibly replacement) date? ....
An obvious questiion is why would the OP have a problemwith the meter being replaced?
Your lucky they are going to change it. I had solar panels fitted, and could not be paid for export until smart meter is fitted, took three months and three attempts before it was changed.
I fear that you did things in the wrong order.
If you were going to need a smart meter in order to be paid for export, you really should have ascertained that, and got the smart meter fitted, before you made a large 'investment' in your PV installaton and batteries etc. (particularly given that the effect of that'investment' could quite possibly be that you will remain 'worse off' {than you would have bee without the 'investment'} for the entire remainder of your life).
I fitted solar panels just at the point when billing agents changed their rules, I had an export meter fitted, but by time I came to register they were no longer accepted.
I also made a mistake, the installers said they would do all the work to get us set up with Scottish Power, but my wife has noted British Gas gave better rates, so decided she would do it all and use British Gas, in hindsight an error, so between delay getting smart meter, and being tied with British Gas for a year, it was 20 months before we got any payment for export, then moved to Octopus and within 2 weeks was being paid for export, British Gas had given us incorrect information telling us we had filled in forms in wrong format, it was their forms, the real reason was we needed a second MPAN number you have one for import and one for export even if using the same meter.
Again hindsight, since you do not need to export to same provider as one imports from, clearly would need two MPAN numbers.
The delay in getting smart meter was part down to the meter board having other stuff on it, and so not enough room for the smart meter.
Looking at this 1782888816135.png I would not be supprised if they have the same problem here. They left me with the boxes the meters came in, to show the solar installers how much room is required, so the solar consumer unit has no lid on it, as tucked into corner of meter and CU box and would not be able to open lid, it would foul on the doors of the cupboard.
At least now I do not have meter readers call, and have to escort them into flat under main house where the meter is, which in winter down some slippery steps, was not really a good idea.
However now to read meter, I need to press buttons, it seems I want Rate 01 ImP, Rate 02 Imp and also a third for Export, but no amount of pressing buttons ever seems to display all, I have to rely on the Phone App to know how much I am using.
Since the solar software also tells me, at least I know it is not too far out, the two are never spot on the same, but near enough to know they are some where near correct.
But with a communal meter, all need to be able to read it, having unwanted info displayed like this Smart meter reading 4.jpg is not helpful when all you want is kWh used. Wonder if they would issue 4 IHD (in home display units) one for each flat? And also 4 or more apps active so all can see what is being used on their phones?
Even with 'dumb' meters, I've hardly ever seen a meter reader at my current house- just a tiny handful of times in about 40 years.
But with a communal meter, all need to be able to read it, having unwanted info displayed like this .... is not helpful when all you want is kWh used. Wonder if they would issue 4 IHD (in home display units) one for each flat? And also 4 or more apps active so all can see what is being used on their phones?
Does such a thing as a 'multi-user' ('communal') 'smart' meter actually exist? That would have to have multiple 'outputs', and I've personally never seen such an animal!
I can think of one straight away but only 3 outlets.
