Yes John, I`ve heard some say so that I think they probably quoting an NIC myth type thingy, does not really make much sense to me either, attached to fabric of building is but one way of having things nice and secure and safe I might be tempted to agree that perhaps but as being the only way in achieving a decent job I would not think that.Your other two 'reasons' make some sense but I'm not sure about this one (even if you hadn't sort-of 'dismissed' it) - who/what says that sockets (or any other part of an electrical installation) have to be attached to the fabric of building?
Hah!View attachment 418657
I’m literally installing a new full-size dishwasher in place of the slimline. The socket is behind the slimline, and unfortunately is about 2mtrs away and the cable is 1.8mtrs!!
Brilliant !Hah!
I did exactly that for my daughter when she moved house.
I'll make a confession on this one; as the existing socket was in the adjacent cupboard - under the sink - and the cable ran from a SFCU, down to floor level and round to the sink cupboard View attachment 418658all I did was remove the socket, pull the cable back and using a 47mm backbox with cable clamp I refitted the socket and left it and the slack cable laying loose under the adjacent cupboardView attachment 418659 - Tin hat applied and awaiting flack![]()
My Grid switch which feeds the socket is on the other wall.. far left so couldn’t do thisHah!
Under them, there is usually a huge void below the cupboard enough to fit a kick space heater.where are you going to run pipes if not in voids behind the cupboards ?
I would agree, we sold our last house still with the original kitchen cupboards 30 years old at least.I do not follow them on that idea because unless they are purely temporay I think they are usually intended to be at least semi permanent - no that`s not usually a reason.
Well my kitchen has at least three supplies, cooker, front of house ring final, and refrigeration supply, not counting lights, so eaiser to simply switch off the RCBO.if needs to be disconnected fairly quickly rather than hunting round to find it and say throw the whole electrics to a home off (which might be in darkness etc) .
OK, yes, but the socket is high up to one side with a hole under it for the plug and cable, so in real terms easy to unplug.Quite often cupboards are full of pots and pans and jugs etc rendering sockets etc not always easy to see and its not recommended to be bashing such stuff into them, its also far from ideal for any flexes etc, ideally I would count these reasons alone as a no no.
That is where mine is also, not a clue if part of ring final or a spur, never really looked.Fair enough, it doesn't bother me at all my dish washer for example has a socket in an adjacent cupboard and I've not touched it for 6 years.
Also my thoughts, I suppose we return to what is installed? What comes under the EICR. However, I have already started a thread about that.Your other two 'reasons' make some sense but I'm not sure about this one (even if you hadn't sort-of 'dismissed' it) - who/what says that sockets (or any other part of an electrical installation) have to be attached to the fabric of building?
True, but I think that would be a pretty difficult and inconvenient place to install pipework. Apart from anything else, it would presumably mean that the pipes would have to be clipped to floorboards, which is not a very clever idea. Also, although under the cupboard, most of the pipes would probably eventually have to 'get to the back', to serve whatever they were there for, and if there were no void behind the cupboards, they would presumably have to go through the cupboards - and would make it next-to-impossible to ever move the unitsUnder them, there is usually a huge void below the cupboard enough to fit a kick space heater.
Yup - unless the consumer unit is actully in the kitchen then it might be a walk to it and (often in older properties) high up or low down in a cupboard and sometimes not always easy to see the correct breaker therefore the whole CU might need switching off at a mainswitch to prevent further damage and if it then becomes a no light or low light situation might cause more hazards or inconvenience at certain times, the option of throwing a nearby switch or easy unplugging is usually far more convenient .Well my kitchen has at least three supplies, cooker, front of house ring final, and refrigeration supply, not counting lights, so eaiser to simply switch off the RCBO.
