On an old 2” cav', with half inch of damp protrusions into the cavity from both sides and a tie wire helping catch the snots, a blocked cavity is a very real possibility.
When the cavity fill was 2 courses below damp and the inner skin was brick the cavity fill was often close to the DPC by the time the plate was going on and the snots off the ties had been knocked off.
They definitely built my old estate in the 1970s with "outie" DPCs, but my current house's 1990 extension has an invisible one.
I guess that at some point in the 1980s someone worked out that you could point over it without the world ending. Plus this way you don't get the crumbly bits above and below as shown in the photo in this thread.
Arguably the outer skin's DPC is hardly necessary anyway, the brickwork above gets pelted with driving rain so it's fairly pointless, and it may even trap moisture above the DPC by preventing it from wicking into the ground. Perhaps using a wider "outie" one on the inner wall could be a sensible precaution though, where appearance doesn't matter. But if protruding inside the cavity it could catch dripping condensation and hold it against the wall.
The bumps in it stop the house sliding away! You'd need a heck of a sideways force to lift the entire house by the 1mm needed to clear the bumps.
You might want to google capillary action. Absent of a DPC the ground moisture can wick upwards by upto 1.2m. And that is not a function of rain hitting the bricks.
Have you never been in a property with rising damp on the party wall between the two properties? That has nothing to do with rain hitting the internal walls. They are internal walls and not subject to rain.
Most of the houses that I work in are Victorian 9" brick walls. When it rains, in most cases, the water evaporates outward. Capillary action is not the same thing as penetration. Gravity only works in the vertical plane.
I'm yet to see any issue from rising moisture from capillary action due to DPC being set back slightly from the external face.
In fact that's not even an issue in terms of rising damp, but gravity is an issue as much, much more water actually soaks down the external face and settles on the DPC.
So perhaps a DPC set-back is advantageous as it will allow the DPC to drain? I'll write to the NHBC and get the standards bought up to the 21st century.
And after all, rising damp on the external leaf of a cavity wall is not even an issue in the first place. It's actually the whole point of a cavity.
In fact the one and only reason that DPC is left projecting, is so that lazy inspectors can see it from the car park one month after the wall has been built.
