My 4 way extension lead says max 3000 watts. It must be ok for 3 x 800 watt panels, maybe it would cope with 4 when it not too sunny?
I know said tongue in cheek, but this is the problem. If more than one per household, how do you stop people doing something daft?
Looking at my power use, max this month 20.3 kWh and Min 10.8 kWh and at that clearly my system is well below capacity, and it is highly unlikely plug in solar will cause any problems except for four sockets clearly marked EPS.
But, like many house designs, the living room is on the sunny side of the house, the ring final circuits are split North side and South side, so in warm weather the South side would likely have both plug in solar and an AC plugged into the ring final.
So with the limit 2000 watt panels and 800 watt inverter that means in essence 800 watts going from the inverter to the portable AC unit without going into the consumer unit.
So we look at
The load current in any part of the circuit should be unlikely to exceed for long periods the current-carrying capacity of the cable (Regulation 433.1.5 refers). This can generally be achieved by:
(i) locating socket-outlets to provide reasonable sharing of the load around the ring
(ii) not supplying immersion heaters, comprehensive electric space heating or loads of a similar profile from the ring circuit
(iii) connecting cookers, ovens and hobs with a rated power exceeding 2 kW on their own dedicated radial circuit
(iv) taking account of the total floor area being served. (Historically, limit of 100 m² has been adopted.)
So if the inverter and AC are around the centre of the ring, unlikely to be a problem, but if biased to one end, overload could happen.
So the question is, can a non electrician, be instructed about the dangers, in any instruction set issued with the kit? As an electrician I had to do a test to show I could read a book, I had the book before the exam and during the exam, and the exam asked questions which were answered in the book, as far as I am aware, the book is only published in English, since I am not fluent in Welsh, it would not matter to me if not published in Welsh, other than it can't be referred to in Welsh laws if not published in Welsh, and if they did, the law would be void.
As to other UK languages I don't know the rules, but this is why we have signs like this
and not written signs. But this
uses a double negative so means end of cycling restriction. I selected cycling, as there are so many errors made with signage, I am sure this does not mean cyclist should run over pedestrians
or even cyclist have priority. Being a circular sign it is a must, this
is optional sign, but we see so many errors with just these simple signs, what is the chance that the instructions in English, Welsh and Gaelic will not have errors?
The number of videos showing multiple solar systems are basically showing the punter this is OK.
