4. Him to actually exist and not be the builder's imaginary friend.Wow!
I'd want three things from a structural engineer
1. His qualifications and experience
2. Confirmation that the whole design is OK
3. His PI policy details
As its plated underneath, do you know the section size (ie depth x width) of the beam internally?The bottom plate looks to be rusty already, not been painted poss where it was welded by the beam supplier
The copied image below shows the beams - inner beam (foreground), outer beam (background). If my eyes do not deceive, the outer beam looks like it's only about 203mm deep or no deeper than 254mm. That applies to both beams.As its plated underneath, do you know the section size (ie depth x width) of the beam internally?
Exactly, and you wouldn't be comfortable with a 100mm bearing on a 10m beam!As said, I never came across installing a 10m beam, but the last thing I would want is any chance of failure.
It must be installed perfectly and exactly as required by the structural engineer.
Anything else would worry me.
No way.Exactly, and you wouldn't be comfortable with a 100mm bearing on a 10m beam!
But!!! We've seen the pictures, and we have seen the issues from the loading.Of course its all down to actual calcs and FoS ,not just this is what we always do, 100, 200, 300, would you fret putting a 10m spanning beam if it had no load on it resting on a 50 x 50 angle bolted to a column??
