- Joined
- 19 Jan 2024
- Messages
- 61
- Reaction score
- 6
- Country
50s build house, has an under stairs cupboard, but it has a door at the rear for access, rather than the side. I believe that these were used as a larder originally, and the wall incorporates a large reinforced concrete slab, the full width of the cupboard, which I removed yesterday. I want to use the rest of the space in the cupboard, if I can.
I've uploaded a photo of this wall so you can see the layout, as well as one of the space behind the wall. I wanted to get some opinions on whether you see any issues in removing this wall, and then support the staircase by adding some battens, screwed into the side walls, which are old, brick sized cinder block? As you are looking at the photo, the right wall is a double skin partition wall, and the left is a single skin block wall.
The staircase is fixed into wooden wedges in the perps in both walls all the way along with large nails on both sides. Any input is much appreciated, cheers.
