Plug in solar
I have wondered where the inverter measures to decide how much to put into batteries etc. I how plug in solar would integrate or not with the existing solar.
As it stands, it does not matter, the tariffs mean I get more for export (12p) to what I pay for off-peak (8.625p) so the easy option is to fully charge overnight and then export when/if the sun is bright enough.
Yesterday was rather a bad day for solar (4.3 kWh) but still enough together with the off-peak, to see me until the next off-peak today started. To try to guess how much off-peak required is near impossible, and should the off-peak become more expensive or the export pay less, then I would need to consider a third battery, and/or some solar panels to catch the morning sun.
I think I am understanding @ebee in that the batteries and plug in solar are separate units, for example a V2G EV outlet plugged into a car, which is a plug in battery, independent of plug in solar, but to have a V2G EV charge point, a G99 would need submitting, output too high for G98, I suppose you can have an EV motorhome with solar panels on the roof, so in real terms we have two completely different plug-in solar systems.
There can be no denial that it is permitted to plug-in portable batteries in the form of an EV. So I suppose it should be called BS1363-solar so it is clear which plug-in system is being talked about?
So is using solar to heat domestic hot water considered as having storage? Even the word battery is a problem, if someone develops a 50 volt cell, then that's not a battery.
However,
the point is, these things are terrible value for money leaving those who are daft enough to buy them considerably out of pocket.
this is true, so in real terms we still do not have plug and play solar.
3.3 Household
A single dwelling unit with its own electricity supply and consumer unit. In buildings containing
multiple dwellings (e.g. blocks of flats, converted houses), each dwelling with its own consumer
unit is treated as a separate household.
That is it would seem incorrect, the local council use very different rules, I have one consumer unit and one meter supplying both main house and flat under the main house, and each has its own council tax charges, its own bins, believe me, I wish that was not the case, it costs me £1000 a year because there are no internal stairs between the two.
I have tried to argue that a 60 amp supply to two kitchens, two bathrooms with electric showers, would never work unless the occupants of both main house and flat were a family who lived together, so did not use both bathrooms at the same time or both kitchens at the same time, but it seems the supply has nothing to do with it, it is all down to the access between the two being external.
So what, the council don't make the plug in solar rules.
Of course we do, only on day two, once things settle prices will drop substantially. If there is only one on the market it will invariably come at a premium.
I had a customer who was quite high up in a national landord association thingy , quite intelligent and knowledgeable chap, good bloke too.
He gave me an example he had with one of his own rentals.
House under rennovation and not yet really fit for renting out in his opinion.
Got a council tax bill and demands etc so he put it to them it was not yet fit for habitation therefore exempt, they disagreed and insist he pay accordingly.
He got in touch with Enviromental dept?? or somesuch of the same coucil and asked if he could rent it out as it was - simple answer - no.
Bext step he was about to do was to get to the chief exec of that council and ask if both the tax and rental overseers got team up and come to one conclusion - was his house fit or unfit to rent out? i am not sure of the outcme as it had a long drawn out correspondance to get the two departments to reach one conclusion according their own rules, I wonder if he ever took such to court.
He could understand one electrical orginisation and one gas orginisation and one building orginisation not agreeing on some definitions of things but not one coucil two departments not having one conclusion to an example - Salor Vee as Delboy may comment!
