He does not have Zero Dwellings either??? .Eric has neither one household (as they didn't bother to redefine "dwelling"), nor two (as neither space has its own supply/CU).
Don`t you just
Since video was made before 27th there were no inverters approved in this country, second one he tried was approved for use in Germany, so should have been OK.Yes, he should have tried an approved one.
Yes, these people who think they know it all, are specially annoying to those of us that do. Taken from a plaque on my father-in-laws work station.Is this an example of a regulation written by someone who thinks he knows what is obvious but in reality doesn't know what he should?
Seems pretty straightforward to me, one household is one that is fed from one supply with one consumer unit.He does not have Zero Dwellings either??? .
Don`t you justlove people making definitions/rules/regulations and the like that appear to have no concept of joined up thinking!
Yes, just like any other solar system.so i guess the panels need to recognise they are plugged into a 240v system before they can switch on ?
They are, they need to match the grid.presumably the prongs on the plug are not at 240v
NO - some solar systems can work independently from the grid !Yes, just like any other solar system.
I would guess most people with an ounce of intelligence would have understood my post - the prongs on the plug will not be at 240v when not pugged in, i wonder what safeguards this rather important requirement, and I wonder if i s this that caused the great delay in them being passed as safe! (and will the inevitable cheap Chinese knock off’s be as safe)They are, they need to match the grid.
Apologies, just like any other solar system connected to the grid. I misunderstood your question.NO - some solar systems can work independently from the grid !
Apologies again, that is correct, they shouldn't be.I would guess most people with an ounce of intelligence would have understood my post - the prongs on the plug will not be at 240v when not pugged in,
The product standard and approved testing and approval procedure, just like existing hard wired solar systems.i wonder what safeguards this rather important requirement, and I wonder if i s this that caused the great delay in them being passed as safe!
So if I fit multi consumer units I can have multi plug in units, OK, I know it means per DNO electric meter. But it seems the law writer was not an English student.Seems pretty straightforward to me, one household is one that is fed from one supply with one consumer unit.
Correct, mine does, only for 4 sockets and one FCU, not whole house, but yes I get some power even with no grid connection.NO - some solar systems can work independently from the grid !
If they have their own supply, yes.So if I fit multi consumer units I can have multi plug in units,
Yes they will, with respect it's what you are doing now.then they will try and twist the wording to suit what they want to do.
It's a starting point, a decision after they have taken account of all of the public consultation and separate investigations/testing. You might not agree with it, not everyone who responded to the consultation did. Some thought the proposals didn't go far enough, some thought they were just about right and some thought it was unsafe whatever things were put in place.But with no battery, over 800 watt is a bit pointless, as just giving it away.
