Electric shower crisis.
28 Dec 2007
Worcestershire
A short while ago we were changing the solenoid valve on my son's ancient electric shower when the top of the valve broke off! Luckily the shower is over the bath. After panicking to turn the water off we eventually got an emergency plumber to cap the pipe. He is managing with a push-on attachment at the moment and various options are being considered. The shower is very old and I don't know the make at the moment.
I see that complete valves for the like of Triton are readily available and I wondered if a plumber might be able to adapt one, rejigging with a suitable fitting maybe.
The obvious alternative is a new electric shower but I think the power supply would have to be upgraded to meet current regs. Or an exposed type plumbed in mixer would be a possibility. He's got a fairly modern combi boiler so I don't think that would be any problem except the cost! Any advice appreciated. IMG_20220903_123525.jpg
Before the break and after.
New unit.
If you need to upgrade the electrics then that's what you have to do!
Or, as you say put in a mixer off the combi which is cheaper and should be a better shower.
But you'll need hot and cold from the boiler... Depends where you can take feeds from.
Time for a new leccy shower. Triton T80 is good, get the highest output you can
Within the power limits dictated by the existing cabling, breakers etc.
It would be poor advice to encourage the OP to wang in a 10.8kW unit on existing 6mm² cable, for example, without qualified on-site assessment.
Yes (as he recognises himself) he’ll likely need to upgrade the cable but it’s daft not to maximise the output of a leccy shower
Can’t work out if Eaton is the model or make, but agree with above, time for a new one, as if you get a spare then something else could break.
I would measure the resistance(s) of the heating can(s), the rated output can then be calculated, a old shower like that may only be 7.5/8.0kW, 6mm2 cable is OK for a 9.0kW shower which gives a ~ 13%/20% power increase & flowrate and would seem like heaven compared to the old one.
Fook sake.
Get heat from the combi.
If cost is paramount then as @Madrab just get a bath shower mixer... You can even get thermostatic ones so all should be good
Mate... What you "would do" and what the average punter on here "can do" are miles apart!
You obviously know your engineering science and SI units but most on here haven't a scooby.
Thanks for all the advice. The name Eaton does ring bells from research I did years ago. I could easily measure the resistance of the old element to work out the current and wattage. We reckon it was an amateur installation by an earlier occupier. The old wiring (red and black) looks like it could be 6mm2 , but it's so old that I've written it off. Unbelievably, It was originally fed from a rewireable fuse when he moved in 22 years ago and I changed it for an RCD. Shockingly, (excuse the pun), a couple of sockets had been connected to the shower circuit so it was a dodgy installation from the start. An exposed mixer shower is the way forward, I think, especially as the combi boiler is in the airing cupboard directly behind the wall so pipework should be straightforward.
