We’ve recently bought a Victorian house. When I removed the skirting boards in preparation for having the walls of our master bedroom plastered, I found there is no insulation in-between the plasterboard and the external timber cladding. The first floor is our master bedroom. What options do I have for thermally insulating this part of the wall? I’ve searched and read a bunch of posts for standard CWI between brick, party, and internal wall insulation. I’m writing a new post in case I should take a different solution due to our different substrate, timber cladding.
From my product research so far, the options I have are:
Is there one option that’s objectively better, balancing performance vs ease of install?
Thanks in advance
- Cavity depth: 80-100mm
- Cavity height: 1030mm
- Cavity wall insulation (e.g. Knauf Insulation DriTherm® 37 Standard Cavity Slab - 100 x 455 x 1200mm | Wickes.co.uk). My concern with this is it bridging moisture from the external timber cladding into the internal plasterboard causing damp.
- Insulation foil (e.g. SuperFOIL SF6 Multi-Foil Insulation - 1.2 x 10m). Looks like the best performance but relatively expensive.
- Insulation boards (e.g. Kingspan TP10 Roof Insulation Board - 2400 x 1200 x 50mm | Wickes.co.uk). This feels like the best bang for buck.
Thanks in advance
