- Joined
- 27 Jan 2008
- Messages
- 29,412
- Reaction score
- 3,615
- Location
- Country
It seems we are just circling around that cistern of yours
clearly not a tank
Well the Latin root means box or chest, so I'm afraid you're wrong as well.It seems we are just circling around that cistern of yours![]()
And that came much later than the original use of the word.clearly not a tank![]()
Then call it Snawdune, that's the original.I hate this idea of changing names
You are slipping the word sharing again, but I think I see where you are going wrong.
Yes, I've been saying that all along. The flat owns the CU, the house has a circuit fed from it.
I've already said that shared things are of course shared.If you and your brother don't share a bedroom, and somebody were to ask you if you had your own room, and you said yes, how would you regard criticism of that on the grounds that neither of you had your own room because neither of you owned it?
"Do people working here have their own company car, or are vehicles pooled?" "They are not pooled, but nobody has their own because they don't own them, they're leased". Would that make sense to you?
I can keep repeating this if you like.
The flat has it's own electrical supply and consumer unit. The house has neither. The CU is not shared like a bedroom or a car, which each user has access to for the purposes of using "it", like sleeping in it or driving it.
I could agree that the flat and house share circuits from the CU, if in fact each uses the same one(s). The CU in itself is not shared.
Say, bedroom 1 in the flat had an external window which let light in. Then say there was another window between this bedroom and one in the house. The house bedroom benefits from, shares/uses if you will, the sunlight coming into the flat bedroom window. But does it share the flat bedroom itself? No, it doesn't, that is still the flat owners own bedroom.
I'm sure I can think of a better analogy, that one came to mind first.
Correct, the circuits may be shared, the consumer unit itself most definitely isn't.To have your "own <whatever>" requires it to not be shared.
I think you'd only need to apply for one at each address and let them run, nothing else.So each year it would need as it stands cancelling one and opening another G98
But as far as the law with plug in solar goes, the question is could I fit two, one assigned to flat and one assigned to main house?
We are required to tell the DNO when removing solar, as well as installing it.I think you'd only need to apply for one at each address and let them run, nothing else.
Maybe, but as it stands, I have no reason to fit extra solar, so does not really matter.But according to that spec you do not have any compliant households.
