- Joined
- 2 Dec 2004
- Messages
- 738
- Reaction score
- 8
- Country
Hi all, I have a separate mains feed coming into my outhouse in 15mm copper. The old stop tap, pipework and outside tap need stripping out and replacing, the stop tap is jammed and I'm relocating the outside tap to the opposite wall. The main stop tap in the street works so I can isolate to do the job.
I'm not sure what is best to do the job. I'm keen on doing it myself but do I learn to solder and use solder fittings, do I use copper pushfit or plastic pushfit for simplicity, or do I buy a pipe bender and attempt to do the pipework run in a single piece (2 bends would be required).
Do I get a traditional stop tap or a lever valve these days?
If I decide to learn to solder I need a blowtorch. If I do the bends I need a pipe bender. Or obviously whichever system I go with I need the fittings as well.
