Can you re-set an intruder alarm system
29 Jun 2007
hi,
I just found out that the house i'm living in (since 3 years ago) has an intruder alarm (pannel was hiding under the stairs), the problem is:
1) Pannel brand is WICKES 3 zones
2) Inside the pannel there was a sticker saying the warranty will expire in 12/05
3) I don't know any codes
basically i've got a fully wired alarm system that is useless unless I can reset it or see the code in my dream??
what do you think my wizzards friends?
its probably a re-badged something else question is what.
I would be inclined to get a new panel
hi breezer,
thanks mate, i probably be better off with a new pannel u're right, i was thinking..
the one i've got is simply plugged in a powerpoint, not like ones u feed from the main board..can i still get a pannel like that??
cheers
it was obviously diy, it supposed to be connected via a fused connection unit, so you cant unplug it
yes lots of diy alarms out there
you can put any alarm panel on a plug, its not really a very smart idea but it's not some special feature either.
This is a long shot but you've got nothing to lose. Unplug it from the mains, open the panel and disconnect any batteries you find in there. Be prepared for a self activating bell to go off outside. Look for ANY batteries in the panel. There might be a small one on a PCB to maintain memory. If this isn't removable short it for a second or two.
Now put all the power back on and try the codes "1234" or "9999". If there's a key marked "Reset" press this first then enter the code.
NB: If this doesn't work and that bell is going off you'll have to get up there and silence it or wait until its battery runs down.
NOT good advice, it will damage the battery, may cause the battery to rupture and may not achieve the desired loss of memory content.
If the battery is soldered in there will (on any decent design) be a battery disconnect link provided. This may be a soldered in link, a low value resistor of a removable link.
I've never damaged a memory back-up battery with a momentary short circuit - or perhaps I should say that the batteries didn't show any signs of damage in that they worked afterwards. Nevertheless, bernardgreen's advice is good. If you can find a battery disconnect link then use it.
save4 the grief and get a new panel.
small panels rarley have a memory battery
You're still going to have to take the cover off to change it though so trying a reset isn't such a bad idea.
This should work, I had a Wickes 5 zone fitted in my last house & used this trick a couple of times. Although a DIY system, it served the family well for the 12 years we had it & as far as I know, its still there. I used to spend a lot of time working away from home & I installed it after I caught someone nosing around in the garden. It did the trick as all of my other 3 neighbour’s houses were burgled over the years! The external alarm bell will (should!) sound when the back up battery is dissed but you only have to do it for a few seconds to return the unit to the default factory settings so punching in 1234 (the factory default code) should silence it immediately. You can then input your own code, assuming you have the instructions how to do it!
Richard C,
have you got instructions mate??? the one i've got is 5 zones not 3 as i said previously (i just had another look)
cheers
my 5 zones panel "Wickes" is a very plain thing it has the following:
-- 8 Leds (mains-day-1-2-3-4-5-tamper)
-- 12 buttons on the keypad (0 to 9 - * - #)
-- that's all
how do i do know when the unit is asking me for the code or anything like that?? is there anybody with an instruction manual
thank you
