I have a light in my hall which up until recently was working fine.
It is controlled by two switches, one at the top of the stairs and one at the bottom. The switch at the bottom of the stairs is a triple switch which controls 2 other lights which are working fine.
The switch at the triple switch seemed to be the master switch as if it was switched to off the single switch wouldnt turn the light on, if the triple switch was on you could switch the light on and off with the single switch.
Now it wont come on at all regardless on how the switches are set.
I recently changed the pendant in the dining room to a hallogen spot light and as a result replaced a ceiling rose with junction box, I dont think this has affected it as they are on different circuits.
I took the single switch off to reveal 2 red wires, one connected to com and the other to L1, and 2 black wires, neither of which were connected. Thinking I had found my fault I connected one of the black wires to L2, but nothing, so I tried the other, nothing and eventually I tried both connected to L2 but again nothing, seems as though there is no power to the switch, checked it with volt stick and nothing seems to be flowing to it.
Any suggestions?
Any suggestions?
