Okay, I'm in a spot of bother. I've had a new extension built and have had new lighting and sockets on a new ring put in. The electrician I hired has done a bunk. The extension is finished and I'm ready to get the DS to sign it off. Unfortunately, the electrician ran off before adding some junction boxes and giving me my part p certificate. Now I'm a little suspicious that he isn't actually qualified. But I can't prove it although I wouldn't be surprised if he ran off because he knew he would be unable to certify it.
Anyway, I got a bit worried about the quality of work so an electrician came in to check everything was okay. He checked it out and said that it was fine, the work had been done well (except that a couple of the overheads weren't fireproof and they needed to be. The water mains also wasn't bonded but he fixed that and I purchased some new lights.
Here's the problem. Although he was a nice guy he said that he wouldn't certify it for me. I totally understand that but that leaves me a little stuck! I can't get sign off without a part p and I'm not sure I can find anyone to certify it for me. Although really there's very little done, because there's a new ring I guess I understand why someone wouldn't want to put their name to it. The electrician (the new one) did his tests on everything and said that it ought to pass (as his readings were fine) but that I would need to find someone else. I've now asked 3 others and all of them said no before even visiting.
So what I'm after is some advice. Am I totally screwed?! Do I have any options? I guess I could get the whole thing re-wired (which I presume someone would be willing to do and then sign off their own work)?
I don't really mind how much it costs, I just need to get it done. Would it be worth getting someone to take all the electrics out and start again or is there a better option?
Thanks for any help you can give.
