Hi
This is my first post and looking for help in my first electrical DIY job in my new home.
Outside my front door there are 2 low voltage halogen lamps which are switched on and off by a switch located inside the house at the front door.I have bought a IQ Ceiling 360 PIR Movement Sensor from screwfix which has an instruction manual on the screwfix website but I dont know how to add a link to this post but I am struggling to make sense off the instruction manual.
The lights each have 2 twin and earth cables connected via terminal block where the two live and 2 neutral connect to the live and neutral of each light then to a transformer for each light.When the inside switch is off both lights have no power to them(test lamps used).
How do I wire up the PIR sensor with this arrangemant.The answer is probably easy but I need help.
cheers
graham
cheers
graham
