I don't think you're given to writing nonsense, bernardgreen, so I presume you're having an off day.bernardgreen said:The point is to find the voltage drop to see if the fault is an undersized cable resulting in under volts at the shower.I can't see the point of estimating or calculating anything, especially approximately - this is a fault-finding exercise.
I know that the point is to find the VD - that's why I suggested measuring it.
My point to you was that I can't see the point of estimating or calculating anything, especially cable impedance.
Overkill. The shower isn't flicking between working and not working on a minute-by-minute basis, so one person and one multimeter is plenty.If the local supply is varying in voltage minute by minute then it will be necessary to have two people and mutimeters and read the voltages at the CU and at the shower at the same time.
