I'm afraid not, Glenda. That boost button only works if your boiler, pump and heating controls are all working. The immersion heater option would give you a simple back-up that would work with the kind of problem that you've just experienced. You may well already have an immersion heater fitted to the cylinder but not wired up to the blanked off point that you have identified. If so it's a simple job to wire up.We have a "boost" button on our main timer unit for the CH and hot water so I guess that's an equivelant.
There is a blanked box with a wire coming out of it but no switch on it.
It seems you have an admirer Glenda!photo! photo!
JohnD, that is not how a gentleman would have answered the question! My guess is you don't have a girlfriend!cylinder
pfriend1";p="768001 said:Hi Glenda,
Dear pfriend 1
Touch wood BG finally sorted out my problem and I have had piping hot water, as normal for a few good weeks. It did take 4 different engineers though to fix it. I think in the end it was a motorised valve that was causing all of the problems and the thermostat was also replaced for good measure.
Hope you get your hot water back soon, particularly in this weather. xx
Oh heck! I presumed that all British gas engineers are fully trained and compentent, particularly as I pay a hefty monthly premium for their services when needed!
I would be so glad on any advice regarding my following problem!
We have a Santon premier water cylinder (model TP150B) which was installed 7 years ago.
Up until last Wednesday we have enjoyed a daily tank of piping hot water ! However, literally from one day to the next, the tank is now only producing tepid water even though the central heating is working perfectly.
I will be on my 3rd British gas engineer visit tomorrow! He changed the motorized valve yesterday to no effect. (Still tepid water and miserable children in almost cold baths!!) Even using the boost button, only produces a kitchen sink full of useable hot water.
Can anyone out there throw some light on the possible variuos causes of the above.
Many many thanks in anticipation
Glenda B xx![]()
