We have signed up for Powergen's heating cover. Before the cover starts they come and do a so called 'safety inspection'. The engineer had to phone his HQ and check if they could cover the pipework as we have Microbore
'Microbore' has traditionally been used to describe 8 and 10mm copper tubing, although I'm sure the term also applies to the 10mm plastic tubing too nowadays.
I think the plastic tubing only goes down to 10mm - probably due to it having thicker walls, as mentioned above.
