Just stick the old taps back on.
use half inch male iron plugs.
use end cap and screw the nut from the pipe onto that?
just stick these on and be done with it.
http://www.screwfix.com/search.do;j...FFI?_dyncharset=UTF-8&fh_search=31319[/QUOTE]
Do I only use the end cap though? Use the nut already on the pipe tap end and screw the end cap onto the existing nut??
Yes that would probably be ok if the existing nut screwed directly on to the tap without an adapter in between.
are you going to reuse the pipes or not ?
