Capping tap pipes
16 Sep 2004
Leeds
Hi
Going to be ripping out the current ensuite shortly. My question is, once I remove the current basin, how do I cap the pipes for taps so I can turn the water back on?
TIA
Will these work given the pipes have tap ends on with a nut on which screws onto the tap?
no , just the easiest one, you could cut the pipes and do what nige f said or use half inch male iron plugs.
