S
saxondale
your close, but still not quite right, its mains first ALWAYS indeed a decent panels would need "kickstarting" to allow battery first
Still no joy Saxo. Tried powering up mains power which illuminated but nothing displayed on the panel and key pad not active. Your suggestion on disconnecting auxiliary and bell I did not try. Is this definately the right thing to do?
Saxo I popped the fuse out of the spur and then disconnected the battery.
Scantronic panels are different. On first power up it MUST be mains first then battery then connect +V.
From that point on it is BATTERY first then mains.
Failure to follow this procedure will invalidate warranty.
LOL - don`t think theres much of a warranty left on a 20 year old panel.
but its mains first everytime
No it isn't. In every case after the initial power up it is BATTERY first. I've just checked the manual for the 9100. I suggest that you do the same otherwise you'll be giving posters information that will ruin their alarm panel. Don't just come back and argue the case - LOOK IN THE MANUAL FIRST.
One example from the manufacturer's literature, Scantronic - 9100, Mains first, & 9800, Battery first.
Many panels require to be Battery first & many panels require to be Mains first, it's all in the manuals.
Also in this thread, resetting following a complete power down is wrong, for this panel (9100) it is >
1. Connect the Mains supply
2. Enter USER code, (the one normally in use, it's held in the NVM chip)
3. Then enter the ENGINEER code, (don't forget to do this properly )'0' then 'Ent' then EngCde
4. Connect Battery
Hope this helps.
