I have used paxoline between the CT chabber and the trunk - The paxoline is gutter bolted to the trunk, and the slot in the CT chamber is slighty oversized to miss these bolts
Removing the main earthing conductor is all that is required to conduct a Ze. This is actually a stipulation of our DNO - I have not done this to keep the NIC happy.
All in, it has taken 5 working days. This includes re-routing many of the cables that previously entered above to enter from the other direction, the removal of several old submains, and a rewire of the pool plant room which this is all sited in - previously clipped direct wiring - thr trunk now goes around all walls with conduit drops down to the pool pumps, calorex heat exchanger etc etc.
A good half a day was also spent running out several hundred meters of temporary cabling to various buildings spread across the site to keep them powered. We actually connected some cables directly into the DB's in some of the buildings, the others just had an array of trailing sockets from our exhibition kit. This also all had to be packed away.
