Onetap wrote
The fact that you have done it many times before doesn't make it right.
It does.
I said under the screed. The chase is formed with the UF insulation. Then the pipe insulated. It could be closed cell polythene or Armaflex
This entire thread has been about plastering/screeding a pipe into a wall/floor chase. It was stated by Hi-Spec, early on, that this did not comply with the Water Regulations and you described that statement as "complete tripe
We have now established that it is indeed prohibited by the Water Regulations, mostly as a result of your posting references that you hadn't read.
Trying to qualify what you had said (i.e., you meant heating systems, you meant in the insulation, you meant under the screed) doesn't alter the simple fact that you were wrong and you are pretty clueless about what you're doing.
Because professionals like copper.
First, you are not a professional; I'd suggest you look up the meaning of that word in the OED before engaging gob.
Second, I like copper, it's great stuff. I like PEX too, it's also great stuff. No-one has used copper for UF heating or plumbing since the days of Levittown.
Its hidden. So will not make any difference.
When it fails, you'll get dragged into a court for civil damages. I suspect the practice is also disallowed in the relevant BS for heating, but can't be bothered to look.
Curiously, I got asked to look at a leak from a shower today. It wasn't the shower that was near the damp patch; it was the radiator opposite. The leak was concealed by the vinyl floor; big slodges of corrosion products around both F&R pipes where they emerge from the floor screed. I left them in the capable hands of their BG CH maintenance contract.
