Foghorn Challenge
  • Thread starter Thread starter Coniferman
  • Start date Start date
C
Coniferman
hmmmm - can anyone work this out?
When the wind picks-up there is a sound like a fog-horn (tone is slightly higher than that) at the back of my house - can clearly be heard inside and outside. I cannot place where it is coming from. Any ideas?
Things I have considered but think unlikely:
1. My gutter downpipe is open at the bottom about 2 or 3 inches above the opening to the drain.
2. Next door have a single storey extension with a chimney on top
3. The "sleepers" under my shed.
4. I thought about gaps in my soffits but they have all been fixed.
I look forward to some weird and wonderful suggestions but hopefully someone will have encountered this and have the solution.
I am in an area of 80's build 3-bed detached.
Houses have always done this. It's called 'wuthering' which is why the book was so named.
It's all to do with the same principal as a aircraft wing making airflow faster due to the pitch of the roof.
If you can estimate the tone of the noise in musical terms then looking up a table of organ pipe length will give an idea of the length of resonant pipe or cavity that produces that tone.
As it is low pitched I would look at long pipes such as the soil stack pipe or chimneys as first options.
Wind blowing across an air brick into an un-filled cavity wall has been known to create very low pitched ghostly groans
(naked man sitting by soil pipe turns to camera and smiles) pa da da dah dah da da
OK, Coniferman, this is not a wind up, we had a bloke from the council here last year sorting out sounds reported from one of the council houses, he put a plastic bucket over his head and could pinpoint where the sound was coming from, in this case it was a stink pipe, (a bird had built a nest in it.)
Right, gone to find plastic bucket! At least the padded cell will keep the noise out :lol:
It sounds quite normal so I can live with it - only when the wind really picks-up. Curiosity really, if no quick fix.
Cavity walls are filled, air bricks are in more sheltered positions, no naked pan pipers !!
Did you scare him that much?
I've had this at different houses.What I discovered was that it was the wind getting underneath flagstones and 'vibrating' them!
Interesting - I do have a patio that needs re-doing - missing pointing etc and slightly uneven. Can't imagine how wind can get under them though?
You made me think also that next door have decking - could that cause it?
The worst thing is that when I hear it, I go outside and the wind stops. Grrrrrrr! Theres me out in the garden in the midde of the night with a bucket on my head stepping from one paving stone to the next. :lol:
