Moving extractor fan to new position in bathroom
10 Feb 2007
Cumbria
I have a fan that needs moving to another wall in bathroom due to shower been installed. Are there end blanks for the 4 inch duct for both sides of the hole as it now stands? As a new hole will have to cored through 1.7 m away, I wanted for it all to look presentable when done!
The above is not electrical question and I'm not a brickie but I would suggest cement fill hole & plaster over the inside of the hole. For the outside your options range from cut a square of something and screw over the hole (unsightly) to getting a bricklayer to patch in matching bricks to match the existing.
Re the new position - you must ensure that the new position is in the zone permitted for the type of fan you have. See the WIKI and/orFAQ for details.
Thanks for your answer, but as there is not a forum for air-conditioning or ventilation I opted for the most obvious! Connecting into domestic electrical circuits is an electrical job isn't it :roll: Or do sparks refuse to core holes through walls these days? Yes I am familiar with bathroom zones and IP ratings.
...do sparks refuse to core holes through walls these days?
Quite often, yes.
Whilst the electrical part of the job may be the work of minutes, the drilling could take hours - use of expensive equipment, difficulty of access, working at height, etc... quite a lot of sparks are simply not equipped to do the job.
Quite often, yes.
No offence, just wanted to find a way to do a tidy job for customer, moving the fan.
Cheers anyway!
