I live in a single storey flat where the cold water to all appliances is mains. Hot water is via a gravity feed from a cold water tank in the flat (height to top of water in tank approx 2.3mtrs) into a copper cylinder with immersion heater. As you might guess, the flow is pathetic! I have bought a Stuart Turner Monsoon 2bar negative pressure pump to install via an Essex Flange and insert in the system to pump all appliances per manufacturers instruction. So far so good.
My problem is that a "friend" has told me that he was advised not to pump a system where the pipework is over 3 years old or hidden in walls or concrete floors due to "Possible splitting of the pipe or joints blowing". My pipework is 25 years old, copper throughout and I would imagine soldered fittings.
Do I heed his advice and put up with hot water dribble or go ahead!
Sorry for such a long post but I'm desperate!
All comments gratefully received.
Big Dave.
Big Dave.
