    Dismiss Notice
Water Pump
Discussion in 'Plumbing and Central Heating' started by Tmon, 18 May 2021.
  1. Tmon
    Tmon
    28 Nov 2020
    37
    Thanks Received:
    Country:
    Hi
    Can someone please offer advice on which water pump to pick? It'll be for the hotwater to the bath and a downstairs shower room, the cold is on mains and the upstairs shower is electric.
    We have a hot water cylinder at ground level (about 5m away from the original wall of the house) which is fed from the cold water tank in the loft (I live in a 2 storey semi). The bath is upstairs.
    Would a Stuart Turner 2 bar Monsoon be appropriate?
    Is this enough info?
  2. Sponsored Links
  3. Rechard Q
    Rechard Q
    19 May 2021
    4
    Thanks Received:
    Country:
    Canada
    Is your need is to pump the hot water to the upstairs
  4. muggles
    muggles
    28 Oct 2005
    13,064
    Thanks Received:
    2,950
    Daventry
    Country:
    Go for the 4.5 bar, it's only £30 more than the 2.0 and will give you a much higher flow rate for filling your bath
  5. Tmon
    Tmon
    28 Nov 2020
    37
    Thanks Received:
    Country:
    Primarily yes. Also for the downstairs shower but that pressure is not too bad.
  6. Sponsored Links
  7. Tmon
    Tmon
    28 Nov 2020
    37
    Thanks Received:
    Country:
    Thanks, I'll look it up.
    Would this require a faster flow in? I'm not sure of the flow rate
  8. muggles
    muggles
    28 Oct 2005
    13,064
    Thanks Received:
    2,950
    Daventry
    Country:
    Yes, with any pump you can't get more out than you put in, but you'll only need the same 22mm supply pipe.
    Quoted pump pressures are theoretical as they're rated at zero flow, and drop off as soon as water is flowing through the pump. Thus the 2.0 bar pump will drop to 1.0 bar with 15 litres per minute passing through. The 4.5 bar will run at about 32 litres per minute at 1 bar maintained pressure
    • Thanks Thanks x 1
  9. Tmon
    Tmon
    28 Nov 2020
    37
    Thanks Received:
    Country:
    One last thing, my builder says it should be negative flow but from the diagrams I've seen online it seems it should be positive. Three setup is mains to water tank in loft - loft to hot water cylinder at ground - water cylinder to bath on first and shower on ground. Nothing higher than the water tank.
  10. muggles
    muggles
    28 Oct 2005
    13,064
    Thanks Received:
    2,950
    Daventry
    Country:
    Yeah positive will be fine
    • Thanks Thanks x 1
Loading...
Share This Page
