My shower stopped working recently due to a leak and therefore I thought I would replace the unit with its modern version. However, when I removed the shower I have observer several things: The old shower circuit that comes from the shower isolator switch has a burnt wire and melted wire and was not being used. Instead the shower was connected to a 0.5mm twin wire (with earth) cable originating from a 3amp plug plugged into the cellar plug socket over a 10 m cable.
I want to make sure I replace the shower correctly so please can someone advise me the best way to do this. I was thinking that I should use 1mm twin cable and fit a proper isolator switch coming off the cellar circuit. Also will I need to get any electrical work like this approved and certified by an electrician?
P.S. The power shower I am replacing is a 130watt Triton Power Shower with internal pump and no water heater.
Thanks for any advice,
Gary
Gary
