We didn't call anyone out,but when we looked under the work top there was the filling loop in a u shape, then there were various different valves small and large valves, we would need a flat screwdriver to move them, also there were mentions of dvc valves or something.Also when there are different valves and a person is not totally sure which valve is for what then it's a bit like a lucky dip as to which one you move then you feel apprehensive about messing up the whole boiler system especially when we are not made of money
I am not so sure I want my number handed out in pubs!
Tony
[/quote]quote="jazmum";p="792725"]The ongoing saga of our boiler we have got the pressure corrected but now an central heating isolating valve is leaking,when last week had an engineer out to look at boiler he mentioned that the white box that houses the 3 way valve gets stuck every now and again.When last night got out another engineer that deals with worcester bosch boilers more often he took the boiler apart and tells me that apart from the isolating valve that needs fixing also the expansion vessel and also about a new fan being put in,i dont want to get fleeced by anyone, if we get work done i want it to be done by what needs to be fixed properly
