I've purchased two 15mm full flow ball valves to isolate the supplies to my power shower. The valves are not symmetrical, but there is not an arrow on the side to indicate flow direction. Does it matter which way they are installed?
I always fit them so they fall into the closed position... was told to do this by Corgi bloke I worked for on Gas pipes, and have done it ever since on everything...
