Let's put it this way.... A Morris Marina was an improved Morris 1000
That is true, and a lot of Marina bits can be used to update the Moggy (disc brakes spring to mind)
I have to disagree on the viva though, the A series BMC was a lot better engine and still supported by parts suppliers now.
If you want to buy one the obvious thing to look out for is rot. The only downfall on these cars was the bottom trunions. If you neglected greasing them they would break. The engines are bullet proof, and unleaded heads are avaible off the shelf. If it sits level all round (check wheel to arch gaps) its solid and the engine sounds quiet then it should be sound. Telescopic dampers are available at reasonable prices to replace the lever arm ones and most of the mechanical bits are shared by other Leyland cars and are easy to get hold of
