If i want to remove a socket from a ring and cannot re-lay cable from the two sockets either side, whats the best/legal way of joining the cables that were in the socket? I can get under the floor boards so would it be a JB under there? is that ok?
JBs must be accessible for inspection and maintenance
(screwed connections sometimes become loose)
Once the floor is down no-one will be able to see it, so they won't be able to find it and access it.
Even if you put a removable floorboard above, it will be useless once someone glues down laminate flooring or fitted carpet.
You could use a permanent joint, depending on your skills and tools available to you you could solder or crimp them and protect with heat-shrink sleeving or something else equivalent to the cable sheath.
