Out of all proportion to the work involved.I was thinking of getting the DNO to come and change to SP, does anyone know what approx cost would this be?
You could, but they might not do it. Is yours one of the ones that will provide an isolator themselves, if requested?If they are changing the supply, i could provide the switchfuse for them to connect into, which would leave a safe way for me to isolate the supply.
That's the theory, but some are relaxed about qualified electricians doing it.If not do they have to come out to pull the main fuse,
The problem then is what happens if permission is refused?or do i just need to contact them to let them know what i am doing and get permission to cut the seal?
I am intending to put a fused isolator either either 80 or 100a within 1m of the meter then run the tails about 8m under the floorvoid.
