Mr extendingsoon, I am not going to get involved in a slanging match with Dr D, he is entitled to his opinion.
My concern is you make what I believe to be an incorrect and potentionally expensive mistake by selecting a Thermal Store.
Dont get misled by sales/technical jargon. Nothing supplies instant hot water. Everything has to heat up plus flow to tap.
A stored water system will supply a given amount of water.
A combi will supply constant hot water at a flow rate.
Non of the above are instant.
Now for the Blue Peter part.
Get a very large drum/tank and fill it with boiling water.
Get a garden hose, connect one end to outside tap, drop as much of the coil into the tank of hot water. Turn on the tap and adjust the flow to get a decent temp rise. The water in tank will start dropping so keep chucking heat into it.
You have now built a very basic thermal store.
The hotter the tank, the more heat can be scrubbed into coils. The more coils/longer your hose the better heat transfer but flow rate will be even greater reduced.
Hopefully in laymans term that explains the 35 deg C temp rise principle with a limited flow rate.
Cant wait for response's to this one.
