I have a problem with a Micron 50FF, where the temperature is set to Max, I have a pipe stat on the flow and return above the boiler, which is only getting to 50 degrees C, the boiler then cuts off and temp drops back to 30 degrees C before coming back on.
The return is always about 5 degrees below the flow temp.
The rads get hot but then only warm.
I replaced the PCB last year, due to a working/not working issue, that cured the problem, but now rads are just not getting hot enough.
Would I be correct in thinking this is a thermistor problem.
