I have recently added an extension across the back of my house. I have created one opening from my lounge by cutting the brickwork straight down from the original back window and made a larger opening from the kitchen supported by two rsjs.
This has left me with the two openings and a central pillar in between, which is where my problem lies. According to the building inspector the two 'skins' of the cavity on this pillar should be tied together. I have been instructed to remove alternate half bricks at either side of this pillar and use bricks to tie across the two cavities.
The problem is however that as you go up the pillar the cavities kind of go out of sync so that if you take a half out of each cavity then a brick would not fit across them. Please help?
I will try to include some pictures as I imagine this is quite hard to visualize from my description alone.
