Buy bigger downlighters
Smart fix but not an option due to design restrictions!
Patch each hole with plasterboard, and have the ceiling replastered.
Did the electrician have required information regarding the hole size or did you tell him/her it was 72mm?
If they had the info then ask them how they're going to fix it.
This metric stuff confuses me. Your ceilings are 2" thick? What are they made of, and how do the downlighters grip the hole? (Even if it were the correct size.)
You need some flexible and heatproof material about 5mm thick (and 5 cm deep?) formed in a circle and glued into place (don't ask what at the moment). TheN finish the surface. With a little care it can be done.
tbh,if you didnt cut the holes,its not really your problem.thats why your sparks have insurance![]()
Told them first thing, thats why im so annoyed at them. It's only 5 holes that are wrong, remaining 5 are ok, thats why i cant change the whole thing.
